Posted by Brownie 450 on July 23, 2012 at 13:54:39 from (66.43.241.198):
In Reply to: 1586 DataCenter posted by farmboycitygirl on July 23, 2012 at 06:58:42:
Try plugging/ unplugging the connector & see if there is corrosion/ crustatia on any of the pins. It is probably the 5 volt regulator IC on the board that is suspect. Could be the LM 317T IC also bad or a loose solder joint.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
