Re: Super C oil pressure
Posted by CNKS on July 23, 2012 at 14:38:33 from (216.144.104.128):
In Reply to: Re: Super C oil pressure posted by J.D.HEICHEL on July 23, 2012 at 10:59:43:
Get the IH gasket(s), they control the clearance. If it had one, put one back, etc. The bottom plate can be sanded flat, or bought new if you need it. You can check the clearance with plastigauge. 3/4 is 50-60 psi. I imagine the oil pump is the problem, I overhauled my Super A engine last year, it stays in the 50-60 range all the time-I did replace the bottom plate on the oil pump.
