Posted by Owen Aaland on July 23, 2012 at 16:16:53 from (216.47.35.39):
In Reply to: 706 pto reinstall posted by rtkman on July 23, 2012 at 08:31:03:
Make sure that the shaft coupler is installed on the shaft so the part without the splines is facing to the back of the tractor. That way the PTO stub can get started before the splines are engaged. After the PTO shat starts into the coupler you can use a pipe wrench to turn the 1000 rpm shaft and override the brakes to get the splines to line up. Once that happens it should slide in the rest of the way.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
