It would have to be a pretty sick SMD to not pull a 3x14" plow.In clay it might be all it wants, but in most soil it should run away with it.
However, If you have mounted a Fast Hitch or if it's a semi-mounted plow using just the lower links of a 3 point, you do not have any draft control or load sensing mounted on anything older than the X00 series. Without that, you have no advantage over a pull plow as far as ease of pulling. We pulled a 3x16" Fast Hitch plow with a 450 in heavy soil and plowing deep when I worked on a S. Dakota ranch in 1964.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
