Re: 706 pto reinstall
Posted by Jim Naden on July 23, 2012 at 18:52:34 from (12.74.49.134):
In Reply to: 706 pto reinstall posted by rtkman on July 23, 2012 at 08:31:03:
I use a remote starter switch to bump the engine over while pushing in on the PTO unit. I rarely need to remove the top link cover to help with mating the splines.
I also coat the PTO bore in the rear frame with a little oil or grease. Always helps to slick 'er up a bit.
