Re: Restoring a 706 American diesel, do they all start this
Posted by mkirsch on July 24, 2012 at 05:14:59 from (64.80.110.74):
In Reply to: Restoring a 706 American diesel, do they all start this h... posted by Deeretrax on July 23, 2012 at 20:17:57:
All you need are different battery cables.
Two 6V batteries in series = 12V.
In order to use two 12V batteries, you need to wire them in PARALLEL. Run a separate + and - cable from each battery to the starter solenoid (+) and the tractor frame (-) for parallel hookup.
The biggest reason going to two 12V in parallel will work better is because you will be using NEW battery cables. You can't convert to 12V parallel without replacing at least some of the cables.
