With out seeing what ya got as for pistons and not knowing what the ing. timing is set at or if the centrifugal advance is sticking or not and like Pete said plug heat range and one other small little thing here your gas . If the timing is set tofar advance or to retarded to far and low octane fuel and idle set to high will cause this. So first check what plugs ya got in it ya do not want HOT plugs like D21's or D18's I have the best results from either 3116 or 386 Autolites or C86 A/C's Next check timing and see where it is at and do this at full throttle and set for 27-29 degrees.Check engine idle and set low idle at 450 -475 . While ya got the plugs out look in the hole and see how far up the piston comes , If the dome stops half way up in the spark plug how ya got normal domed pistons IF that dome goes way on put ya have the hight alt. pistons and here your going to need to up the octane rating of the gas ya burn . Check the cent. advance and make sure that it is working and not sticking in retard .
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
