Re: Should I convert my 400 to 12v?
Posted by Nebraska Cowman on July 24, 2012 at 12:25:02 from (166.182.3.201):
In Reply to: Should I convert my 400 to 12v? posted by Evan From IA on July 24, 2012 at 12:15:47:
I'd convert it Evan. 6 volt was marginal at best and somebody will tell you to keep it original but 12 will sure make it easier to start. If you put on a 12 volt regulator you should be able to get the generator to put out enough voltage, otherwise either find a 12 volt generator or switch to an alternator. If you go to negative ground make sure the hot wire from the switch hooks to the positive side of the coil and the neg side goes to the distributor and add a resister between the switch and the coil. And of course you will have to change your light bulbs. The starter will be fine.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
