A lot depends on what your going to do with it. If you plan to run it 12 months out of the year then yes switch is so you know it will be more likely to start in the dead of winter. If your going to turn it into a show tractor leave it as is. If the engine is getting old and low on compression yes 12 volts will help it start better. Most of the tractor I run across end up getting switched out due to the fact any more it is cheaper in the long run to do a 12 volt system over the 6 volt system and they are a tad bit more dependable on 12 volts as for starting when you want them to
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
