Re: Should I convert my 400 to 12v?
Posted by IAtractorKid on July 24, 2012 at 14:35:51 from (184.97.63.73):
In Reply to: Should I convert my 400 to 12v? posted by Evan From IA on July 24, 2012 at 12:15:47:
I always look at it from a cost standpoint. Typically when i buy a tractor, it requires a new battery and wiring anyway so that is a wash. However there is a significant cost difference between a new generator and a new alternator. If the generator is still good, i leave it on there otherwise it gets converted because the alternator is cheaper. 4 of my tractors are 12v and two are still 6v. 6v works just fine, even if you have bad winters or the tractor sits alot, as long as you have a good battery and good battery cables. With 6v you need big cables!!! I use double-ought.
