Farmall SMTA Timing
Posted by clay mcnamara on July 24, 2012 at 18:29:51 from (174.125.227.91):
Having trouble with this... Had the head rebuilt, now runs like its out of time. Heres what i did: Compression stroke on #1 cyl, TDC, the timing mark hits right on the little timing mark, distributor right on #1 cyl plug wire. Tractor runs out OK but labors...
I even shined the timing gun on it, and it is a bit off, if you move the distributor to where teh timing mark hits the crank shaft mark, its way off time and runs even worse.
Valves set correctly hot, tractor has electronic ignition. What am i doing wrong?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
