Re: Should I convert my 400 to 12v?
Posted by oldtanker on July 24, 2012 at 22:48:09 from (66.228.255.239):
In Reply to: Should I convert my 400 to 12v? posted by Evan From IA on July 24, 2012 at 12:15:47:
I converted my M to 12 2 years ago. A tractor that wouldn't start when needed at -10 now starts at -25 with no problem. For anyone considering a conversion......
1. Make sure the ignition system is in top shape before doing anything.
2. Make sure the carb and fuel flow is working right.
3. Check compression!!!!!
4. Repair any and all problems before doing a conversion! Even if that means an engine rebuild! If you don't all 12 volt is is a bandaid masking another problem.
Then once everything that can affect starting is problem free decide if 12 volt is what you really want.
Reason to stay 6 Volt....keeping a tractor original because it's a tractor that has been in the family for years or a show tractor.
Reasons for converting.....better starting in all weather conditions. Compatibility when jump starting may be needed (my wife would never try to bump the post on the starter when jumping from 12 to 6....it sparks), Cheaper batteries!!!!! The fact that 6 volt chargers are getting harder to find and more expensive. I have purchased 2 chargers in the last couple of months. One for my boat batts (12 volt only)and a large charger with 200 amp boost to replace one that died. Old big charger was both 6 and 12 volt. New 250 dollar charger is 12 only. Hand writing is on the wall for working tractors.....12 volt unless you have extra money to spend! Last good quality 6 volt batt I purchased was $90. Last good 12 volt was 60.
Rick
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
