Farmall 240 Restoration - Issues Help Needed.
Posted by farmallhal on July 25, 2012 at 05:28:41 from (76.4.182.42):
Took most of the sheet metal off yesterday and ran into a problem with getting the governor control handle off at the dash. Checked the parts catalog for any clues and found no keys or other entrapment devices shown. I believe (don't know for sure) the shaft is splined and the handle is pulled down rather tight with the locknut on the top. How is this handle separated from the shaft at the dash??? Also, the slotted screws attaching the instrument panel to the rear hood over the gas tank are frozen and won't budge - thinking I am going to have to grind them off but haven't done so yet - any "tricks" for removing them, ie. impact screw driver?? Thanks for any suggestions, Hal.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
