Posted by Roger46 on July 25, 2012 at 15:31:11 from (70.198.2.40):
I have a Farmall 350 Diesel that I completely rebuilt several years ago. The problem I have had since then (and seems to be getting worse) is that when the head was reworked at the machine shop they didn't do anything with the valve push rod tubes that go through the head to keep them from leaking oil. Six of the eight leak to some extent with oil running down the side of the engine. I looked in the parts manual and they don't show any seals or o-rings. How are they sealed in the first place? Does repair require removal of the head? I took the valve cover off (not an easy task with the power steering unit overhead) and cleaned around the tops of the tubes and put a layer of gasket cement around the top of each tube and it stopped most of the leakage, but it is starting to leak more again. Any advice would be appreciated. Roger
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
