Re: 400 won't start without battery charger
Posted by farmallhal on July 25, 2012 at 15:42:33 from (76.4.182.42):
In Reply to: 400 won't start without battery charger posted by Evan From IA on July 25, 2012 at 12:40:58:
In addition to what has already been suggested run your ground cable to one of the starter mounting bolts at the tractor frame. I've had very good luck with 6 volt batteries but get the best ones I can find. I also use nothing but 00 cables with soldered terminals and use those external tooth washed at each connection to get a good bite into the metal. All connections should be bright and shinny clean, Hal.
