I would try cleaning the connections at the ignition switch & solenoid on top of the starter, after making sure the battery cable ends are shiny bright also. Any corrosion robs a 6 volt system of much needed amperage. High quality copper battery cables double ought in size usually help a lot, a welder friend of mine offered me some of his discarded cable he had lying around & it works great. I soldered new terminal ends on them both.
The larger cables offer less resistance. Any wire you need to replace, go with 10 ga copper, less problems down the road.
I would go with the highest cranking amp 6 volt you can find, the heavier the battery the better, this means the lead plates inside are either bigger, or there is more of them.
The best ( and most expensive) I have found, BUT at least you never have to worry about rust in the battery box again :
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
