A leaking rear seal is usually an indicator the main & thrust bearing on the crank are just begining to wear. I have seen them with just the retainer coming loose and that is usually very lucky.
Drop the pan & plastigauge your mains. Take a dial indicator reading of the front to back crank movement, if they are within specs, it's probably the rear main seal retainer.
But to replace either, you will have to split the tractor.
How much oil is it leaking?
Does it leak most when the tractor is running or sitting?
This post was edited by rhtx55 at 21:05:12 07/25/12.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
[More Ads]
