Re: H will not throttle up
Posted by JRSutton on July 26, 2012 at 04:44:13 from (75.130.109.233):
In Reply to: H will not throttle up posted by Berghandler on July 25, 2012 at 17:33:29:
Just some rough guessing here -
probably not the governor - the governor only opens or closes the carb, it wouldn't make the engine stumble. Rule that out for now.
Do a quick check to be 100% sure your plug wires are connected in the proper order. Crossing a couple can result in some very weird behavior. Might as well make sure each one is sparking while you're at it.
Make sure your choke is operating properly. Take the air cleaner hose off - make sure it's opening fully.
Assuming you're using fresh gas...
If that all checks out - and it's dying upon opening the throttle, it's most likely too high of an air to gas ratio. That means you're either getting too much air, or not enough gas.
Check for leaks at the carb mount and intake manifold to head.
Make sure gas is coming from the tank to the carb in a steady stream.
Sounds like it will be - sounds more like blockage in the carb.
Pull the carb apart and go through it all one last time, cleaning every little passageway you can find - be obssesive. blast everything with compessed air. Use torch tip cleaners to push throgh little passageways. You may have missed something.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
