Re: 400 won't start without battery charger
Posted by El Toro on July 26, 2012 at 04:57:32 from (108.3.148.85):
In Reply to: 400 won't start without battery charger posted by Evan From IA on July 25, 2012 at 12:40:58:
Use a hydrometer and check the specific gravity in each cell and compare the readings. Should see around 1.275 on a fully charged battery. You may have a weak battery cell. As been mentioned use 00 cables welding cables are ideal for battery cables use soldered lugs and don't make the cables any longer than necessary. Clean all surfaces until shiny including where your battery is grounded. If one battery cell has a reading of 1.100 you have a dead cell. Hal
