I am no mechanick but the key here is when you have the battery charger hooked up where are the charger leads hooked to? Are they hooked to the battery cables at the post or elseware? If hooked at the post then your wireing is OK or the charger curent would not go thru either and that the battery is either not making contact with the clamp or the battery is bad. Now if you are hooking to someplace other than the battery ends on the cables then you have a wire problem. To check for that hook the ground to battery and try using the spot where you are getting it to start, then do the same proceduar with the positive post and it will tell you if you have a positive wire problem or a ground problem. Charger hooked directly to starterand not using starter button does it crank better and if battery ignition will it start that way, a week battery would provide enough power for just the points but not starter and points.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
