YES
Posted by John T on July 26, 2012 at 07:16:15 from (216.249.82.117):
In Reply to: 6v gen posted by PeteEllis on July 25, 2012 at 15:48:20:
I have done it and it worked, a genny dont necessarily know its output, thats increased if it spins faster and/or you pump more current through its field windings (what the VR regulates). NOTE BEFORE ANYONE HAS A CALF Im NOT saying that engineering correct or it charges at any high rate, Im ONLY SAYING as an engineer and one who has done it, YES IT CAN WORK. Of course, a genny shop can easily convert it, they change out the field windings, thats the engineering correct way to do it
John T
