Posted by Matt E. on July 26, 2012 at 07:55:26 from (173.216.243.151):
In Reply to: 1948 Cub push blade posted by Matt E. on July 26, 2012 at 07:21:22:
Thanks Denny.
So from your pics, it looks like all we're missing the long bolt that goes through the square tube under the front bolster (sorry I don't know what that part is really called) and the two square "centering" blocks that look to keep the rod in the middle of the square tube. I assume the set screws hold the blocks in place.
The only part that doesn't make sense on the pallet picture is the short arm that looks to be newly painted. I don't see that on my blade set up nor do I see where it should go.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
