Posted by Matt E. on July 26, 2012 at 08:06:07 from (173.216.243.151):
In Reply to: 1948 Cub push blade posted by Matt E. on July 26, 2012 at 07:21:22:
Oh, ok now I see what that part is for! It is for the belly mount on the rock shaft. So that might explain what the extra drawbar was for that also came with it! Does this mount in front of the normal drawbar? I think the long rod is for a rear cultivator?
I think if Dad mounted in the front, he could get away with just hooking the lifting rod directly to the rockshaft to lift the unit instead of attaching the part that we don't have. If it binds, he may have to fabricate something but he'll be happy to know how it all hooks up!
I'm in Missouri and he's in western Montana. He wanted to be able to push rocks off his road to his hay field that seem to roll off the hill every year. And he'd have a use for the Cub, that and be able to push a little snow also in the winter.
Thanks for the help guys!
This post was edited by Matt E. at 08:07:27 07/26/12 2 times.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
