Posted by Harold H on July 26, 2012 at 12:32:11 from (12.23.230.67):
In Reply to: 1948 Cub push blade posted by Matt E. on July 26, 2012 at 07:21:22:
For grading it generally works best and gives smoother work, if mounted in the center. I believe you have all of the parts for that position. Front mount in buldozer position is harder to control. I think all you need for this is a piece of all thread and some square spacers to go on the all thread in the square hole.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
