Posted by Ol' Gimpy on July 26, 2012 at 14:17:44 from (74.67.127.235):
In Reply to: 1948 Cub push blade posted by Matt E. on July 26, 2012 at 07:21:22:
Have the correct center mounting bolts here,one rod appears to be homemade,missing the arm/bracket that bolts to tractor rockshaft,and the mounting square "Blocks". I call these the "Second Series" Cub blade.Later ones were modified slightly,sold as the Cub 54-A blade.As the guys said,TM Tractor Parts makes reproductions of some of the always missing parts.Mauals show up on eVilbay,likely from Binder Books as well.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
