Re: Is it worth it to restore a Farmall 1947 H
Posted by sflem849 on July 26, 2012 at 16:02:03 from (69.197.84.39):
In Reply to: Is it worth it to restore a Farmall 1947 H posted by Mike James on July 26, 2012 at 14:53:12:
You can crank as much as you like (within reason) with the 12v battery and 6v starter. You don't need to rebuild the starter when you convert to 12v.
The easiest way to start a tractor with a mag and no battery is with your truck and a chain. Put the tractor in fourth and pull it. Let out the clutch and it should start right up.
