Consider this. At the moment, at least in the U.S. there seem to Farmall H tractors everywhere and you can buy them cheap. Fast forward ten or fifteen years and there will be far less of them and they will be far more expensive. Over here in Australia, where there are fewer of them, they already command much higher prices than in the U.S. As for buying any F series Farmall, they are nearly impossible to find. I should also point out that I am biased in favour of saving pretty much any old tractor. It seems such a waste to turn them in Kia motor cars and such.
If you do want to turn the motor over, you can easily get hold of a Farmall H crank, on ebay if nowhere else, for a very small sum. Remove the spark plugs and inject a decent dose of thin oil. Remove the rocker cover and oil the valve rockers. Turn the motor over slowly by hand and check all valves move freely. Then, if you are fit, do what I did for the Farmall M I bought. Crank the motor over until the gauge shows oil pressure. If you have a battery, turn it over on the start. Only after this, should you replace the plugs and try to start it. That way you won't break rings if the beast fires up and runs flat out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
