Posted by SadFarmall on July 27, 2012 at 05:43:50 from (121.79.27.38):
In Reply to: 6v gen posted by PeteEllis on July 25, 2012 at 15:48:20:
You do not need to spin the generator faster. The voltage regulator (not the cutout) just regulates current flow to the field coils / pole shoes. Yes, a 6 volt generator will operate at 12 volts, BUT you should be careful. A generator in excellent condition internally will tolerate the change, so long as you do not increase the current output too much. However, if the internals are a bit tired (weak insulation etc) there is a serious risk of starting a fire. Personally, I would just fit a 12 volt generator. I presume that Delco-Remy manufactured 6 and 12 volt generators just as Lucas did. I had the option of fitting a C39 or C40 Lucas generator at either 6 or 12 volts. Even the voltage regulators look identical, apart from the 12V stamp.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
