Re: What Lubricant For Steering Gear Housing - Farmall 240
Posted by LA in WI on July 27, 2012 at 05:54:03 from (50.50.78.146):
In Reply to: What Lubricant For Steering Gear Housing - Farmall 240 posted by farmallhal on July 26, 2012 at 15:31:05:
Hal, just in case 80-90 wt would leak out, I used 140 wt and it works very well. Easier steering than when I had grease in it.
Hope you get rain; we had 1.1" last wk and .3 this wk....lawn getting a little green again.
Lowell
