Re: Broken splines on bull shaft 400
Posted by Andy Martin on October 04, 2000 at 21:03:09 from (38.31.74.199):
In Reply to: Broken splines on bull shaft 400 posted by reddude on October 04, 2000 at 19:30:53:
Inspect the mating part carefully. You should probably reinstall with the same splines in the same grooves or you may break more. You should be able to tell which grooves have less wear. Reinstalling in a new orientation may put more load on splines from the groves with less wear and break one or two additional splines off.
You may have one bad groove which has broken two splines during different installations, i.e. someone removed the shaft, found a spline broken, and reinstalled two splines away, then broke another spline from the same bad groove.
Post A Followup
: Re: Re: Broken splines on bull shaft 400
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
