Re: What Lubricant For Steering Gear Housing - Farmall 240
Posted by farmallhal on July 27, 2012 at 16:56:12 from (76.4.180.219):
In Reply to: Re: What Lubricant For Steering Gear Housing - Farmall 240 posted by rustred on July 26, 2012 at 17:23:40:
Thanks for the response and suggestion. I will probably go with some type of gear oil as there is no leakage or seepage at present. I feel the grease is a superior choice once the seals and bearing get some wear when the leaks begin, Hal.
