Posted by farmallhal on July 27, 2012 at 19:20:38 from (76.4.180.219):
In Reply to: Re: M 12V Conversion posted by Sparky7018 on July 27, 2012 at 18:11:52:
Sparky, Don't know anything about an external regulator but you might be thinking about the ballast resistor which is used to reduce the voltage to the points to 6 volts so they have a normal life. The ballast resistor goes in the wiring prior to the coil unless you are using a new 12 volt coil which has one built in. Most folks retain the existing 6 volt coil and use a ballast resistor which is much less in price then a new coil. Hope this adds some clarification and not confusion to your conversion as the regulator is internal in the alternator, Hal.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
