Re: IH 484 Hydraulics issues
Posted by pete 23 on July 27, 2012 at 19:31:34 from (74.32.238.2):
In Reply to: IH 484 Hydraulics issues posted by njfarmer on July 27, 2012 at 18:37:50:
I have an idea, if the filter doesn't help you out. That tractor is kind of divided into two sections in the frame. The pump pulls oil out of one section and dumps it back into the other section. There is a lube pump that pumps lube oil out of that section and in the process of lubricating it returns the oil back to the section the main pump pulls oil out of. There is a screen on that lube pump and it commonly gets plugged with the remains of the hand brake linings. You can access that screen to clean it from behind the big round plate if I am remembering that part correctly. So, one section gets over full and other section starves if that lube pump for any reason does not do it's job.
