Re: SA Steering housing
Posted by JRSutton on July 27, 2012 at 20:09:16 from (75.130.109.233):
In Reply to: SA Steering housing posted by equeen on July 27, 2012 at 19:33:02:
third party image
third party image
You're not doing anything wrong - it's just being difficult.
Here's a few pictures to help confirm what you probably already know should be on the other side. Nothing fancy - that bearing just needs to slide out.
Try to get something under the gear to give you some leverage.
If all alse fails you could use a torch to heat up the casting around the bearing - just don't go too hot - you don't want to crack anything.
Sometimes warming it up a little bit is enough to loosen the grip.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
