Re: farmall A want start
Posted by El Toro on July 28, 2012 at 08:26:54 from (108.3.148.85):
In Reply to: farmall A want start posted by alabama boy on July 28, 2012 at 08:07:16:
Disconnect the gas line at the carburetor and hold a clean container to catch the gas. Should have a full stream of gas from the tank. If there's just a trickle of gas your tank needs cleaning. Check the glass sediment bowl to see if its full of gas or needs cleaning. Also since it won't start hold your hand over the throat of the carburetor while a helper makes an attempt to start the engine. It may be better if you make the start and have the helper hold his hand over the throat of the carburetor since you're familar with the tractor. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
