Re: oil pump rebuild - 1945 B
Posted by old on July 28, 2012 at 08:43:57 from (209.86.226.19):
In Reply to: oil pump rebuild - 1945 B posted by Matt E. on July 28, 2012 at 07:47:54:
As Dave said the plate on the end needs to have no marks or scratches on it. I clean one up years ago on an 8N by using some of that sand paper made for a drill disk and glued it down on the top of my battery charger and went to work on the plate that way and it worked real good and the charger was bit enough to stay in one place which also helper the work. Before I started doing the plate the oil pump had almost not pressure after it had good pressure
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
