Re: farmall A want start
Posted by old on July 28, 2012 at 08:48:56 from (209.86.226.19):
In Reply to: farmall A want start posted by alabama boy on July 28, 2012 at 08:07:16:
Blue white spark is only part of what you need with a spark. It also needs to jump a 1/4 inch gap or more also and if it does not then no start. Not likely to be your problem either but just so you know.
Next pull the carb drain plug and make sure you have a good steady flow of gas there. Catch it so as to look for dirt/rust/water. Let it flow few minutes so you know it will stay flowing. Bet you find you have a poor flow and if so work your way back till you find where the clog is. You may even have to blow air into the tank to clean things up. Had a problem sort of like that in my BA and had a couple old leaves in the tank that would float over the hole for the fuel and stop it up then when the engine died they would float off till it happened again and boy was that hard to figure out
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
