Re: farmall A want start
Posted by JRSutton on July 28, 2012 at 13:14:05 from (75.130.109.233):
In Reply to: farmall A want start posted by alabama boy on July 28, 2012 at 08:07:16:
When you get to the bottom of the tank - you can often get crud in the line - moreso when the tank is full.
Don't ask me to explain the physics behind that -I don' know - it just seems to be the way. Maybe it's floating crud?
Either way - my guess is you've got crud in your gas line - or that worked its way to your carb.
pull the gas line - make sure you have a steady stream the carb.
If so - I'd pull the carb and give it a good cleaning.
