actually I learned something new with these engines - both plugs fire together.
the intake/exhaust stroke is 180 degrees off as you'd expect between the two cylinders so one is firing and one is exhausting - but apparently the plugs fire twice in each cylinder - once on compression, once on exhaust.
The firing on the exhaust stroke doesn't doing anything - just makes the magneto simpler.
There is no rotor.
Probably common knowledge to this crowd - but I've never seen it before (or at least I never knew what I was looking at if I did see it).
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
