Re: SW6 knock in rear end
Posted by rustred on July 28, 2012 at 21:45:31 from (184.151.222.186):
In Reply to: SW6 knock in rear end posted by tractorboy27 on July 28, 2012 at 21:41:39:
have you checked the wheel hold down clamp bolts. if the clamps are loose it could produce a knocking sound.
or could be rear axle brg.
