Re: 400 gas tank split?
Posted by rustyfarmall on July 29, 2012 at 08:32:23 from (67.55.162.174):
In Reply to: 400 gas tank split? posted by Evan From IA on July 29, 2012 at 07:42:26:
Go down to your local home store and get a couple gallons of muriatic acid. Plug all the holes in the tank, pour the acid in, put the cap on, tip the tank up one end, then the other end, and from side to side several times, and then let it set. Repeat the process a few times and then pour the acid back out (it can be reused). Rinse thoroughly with water, and then let it air dry out in the sun. The tank will look like brand new inside.
