Re: 400 gas tank split?
Posted by gene bender on July 29, 2012 at 09:20:14 from (67.55.226.123):
In Reply to: 400 gas tank split? posted by Evan From IA on July 29, 2012 at 07:42:26:
Wont work there are several cleaners like other post said get some muratic acid that will work well. there is also soap and water with nails,rocks and other stuff shake it around and drain mite have a bad tank and when the junk is out could leak. I built a tumbler with a gearhead otor and let them tumble using various stuff to clean like new again. Even cleaned one using vinegar as the old gas had lift a scum. Ive done several and not are all the same with deposits.
