Re: Wheel weight bolts[what size]
Posted by RPM1941 on July 29, 2012 at 10:14:54 from (173.23.76.185):
In Reply to: Wheel weight bolts[what size] posted by larryanderson on July 29, 2012 at 06:09:34:
The cheaper & faster way is get 4 of 36" 3/4 nc std redi-bolt/threaded rod, saw them in half. The IH system was made of special grade 5 square head 3/4 nc bolts, if you were going to put 3 or more per side to make sure they wouldnt break in the field, it was a complicated mess because of odd length bolts. If they failed & break off tire valve core with 20.8x38 with fluid you have another mess.
