Re: 400 gas tank split?
Posted by Evan From IA on July 29, 2012 at 10:23:14 from (207.199.214.195):
In Reply to: 400 gas tank split? posted by Evan From IA on July 29, 2012 at 07:42:26:
Thanks for the replies! If that muratic acid isn't too expensive I'll give that a shot. By "gunk" I mean a thick "1 inch" residue at the bottom of the tank due to sitting for 4 years with a alomost full tank. I couldn't move the gunk with a flag wire, but I could push the wire into it.....barely.
