Posted by rhtx55 on July 29, 2012 at 12:42:37 from (207.119.47.83):
In Reply to: 400 gas tank split? posted by Evan From IA on July 29, 2012 at 07:42:26:
Muriatic acid would be my last resort, that stuff is very agressive, and make double sure you get it neutralized.
If the "gunk" is gasoline residue I would first try pouring in some carb cleaner or berryman's chemtool and let it soak a couple of days.
If it is rust residue I would use a gallon or two of vinegar, let it set for 24-48 hours, rinse & then fill with water & add cup or two of baking soda to neutralizethe acid residue left from the vinegar, I would let this soak overnight also.
I have had a tank on an H, and later an F20 I took to a local radiator shop, they split the tank at the seams, ran them through their tanks, they re-attached the baffles, fixed any holes or leaks, resealed, and pressure tested. I had them send them out to have dipped & re-galvanized.
I beleive it was around $175 ea back then. The H tank was leaking as the bottom had rusted through, the F20 tank was badly dented, and needed a new coupling welded into the bottom for the sediment bowl.
Any liquid such as evaporust etc. may give you good results, it might take quite a few applications, depending on how bad the rust is. There are many products such as POR-15 to reseal the inside once you get it clean, but follow directions carefully, I have seen tanks that had sheets of this stuff floating in them, probably due to a poor prep job initially.
This post was edited by rhtx55 at 12:56:23 07/29/12 2 times.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
