Re: Super A Water Pump?
Posted by Ed Fisher on October 05, 2000 at 09:59:17 from (208.246.136.52):
In Reply to: Super A Water Pump? posted by BIG on October 04, 2000 at 11:53:34:
I have a 51 SA that I mow lawn with. It always seemed to be running a little hot and it would spew water out the overflow tube when I would go down a steep grade. I installed a water pump from a SC on it and did NOTHING else. It works excellent keeping the engine cool and it doesn't spew water anymore. My experience with my tractor tells me that you DON'T have to change to a pressure system as mine works real well. The pump installs in place of the lower water inlet fitting. I had to remove the radiator to install it. When purchasing one besure to get the plate that attatches to the back side of the pump. Some rebuilt pumps come without this plate. Good luck. Ed.
Post A Followup
: Re: Re: Super A Water Pump?
