Re: Whats a good Gravity flow filter
Posted by rustyfarmall on July 29, 2012 at 14:06:50 from (67.55.162.174):
In Reply to: Whats a good Gravity flow filter posted by John G. Hasler on July 29, 2012 at 13:49:56:
Exactly!! If the sediment bowl is in place, with the correct screen in the top, and the correct fuel inlet fitting WITH the sreen is in place, there is NOTHING that can get through that will cause any problems in the carburetor.
I have rebuilt way too many Farmall H and M carburetors to let anyone CONVINCE me that any kind of in-line filter is needed.
Also, please realize that 60 to 70 years ago, gasoline was not nearly as clean as it is now, and also that MOST tractors from that era were refueled with 5 gallon gas cans, which provided even more chances of introducing contaminants into the fuel system. The sediment bowl filtering
systems worked very well back then. No reason they won't work just as good today.
