Re: Whats a good Gravity flow filter
Posted by John M on July 29, 2012 at 15:24:30 from (67.231.174.210):
In Reply to: Whats a good Gravity flow filter posted by biggerred on July 29, 2012 at 07:32:23:
To answer your question, Napa has/had one that worked great on my M. Cost about 5 bucks. I also found one at Advanced Auto that you can use either on rubber or steel line, depending on which one you buy, and you canhge the filter inside and is clear so you can see the junk that wondeful sediment bowl misses.(Im not sure the AA one is for a gravity system, but I do recall the pics showing it on a motorcycle. Itsa Mr gasket BTW.) Me personally, I done care what anyone says, its my tractor, my carb, and my engine those micronic peices are eating up!! Id much rather not have them go in there!!
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
