Re: Rebuild C-113?
Posted by El Toro on July 29, 2012 at 16:50:36 from (108.3.148.85):
In Reply to: Re: Rebuild C-113? posted by equeen on July 29, 2012 at 13:50:55:
Measure your old sleeves bore diameter and length. Originally the sleeve bore was 3", but if the engine was rebuilt sometime ago an over bore kit may have been installed. If it has 3-1/8" pistons you now have 123cid. I used an overbore kit back in 1975. No machining is required, but you need to measure the length of your old sleeves. Should be 6-7/8" long. Hal
