Re: MW hand clutch removal?????
Posted by D Slater on July 29, 2012 at 19:42:06 from (184.15.5.50):
In Reply to: MW hand clutch removal????? posted by jmducks1 on July 29, 2012 at 15:05:41:
Sould be 6 bolts. If the adapter plate is stuck to the adapter housing it has a oring and fits tight in the housing the 6 bolts come out of. That housing needs to stay in place to the transmission housing. When the adapter plate is out of the way regular IH size bolts need to go back in the housing. When the adapter parts are out a M&W bull pinion shaft with a bearing comes out and then is replaced with a regular SM type bull pinion shaft. Other fellows are thinking about band brake M tractors when saying the axles and bull gears need to be removed. On a regular SM a plate that the inside disc brake shoe contacts holds the bull pinion and bearing in and has the shaft seal and is also a tight fit with oring. On the M&W set up the adapter plate and round part of the adapter housing hold the bull pinion and bearing in.
This post was edited by D Slater at 19:51:47 07/29/12.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
